OK FOR MY NEXT TRICK
La La Land
i shall make this bent up and broken Steam Genie...
into a complete and brand new functioning Direct Drive.....
I will take you step by step thru the process wit pictures!
If you don wanna see it here ..
i'll take it to the Rubber Room!
The Start:
very bent up!
much massaging later
finally straight see the new legs
FB7777
bawb, you look like a retarded beekeeper with that hood and fatman bodysuit on
La La Land
we're getting there..
Stainless Steel Hex close nipple fitting welded on...
first it'll be primed wit the sef-etching primer..followed by the 2K epoxy
ready to spray!
what color shall we paint it???
La La Land
powder coating does sometimes chip which leaves an un-primed surface which will rust...my 2K epoxy system is bullet proof....an YES that IS a Mikey tee!
The Preacher
bob vawter said:
now for some sandblasting!
looks like the hot rod riding lawn mower is broken down????? :?
PS now i see why you have a heart problem. you must go 3 and sum change on da hoof!!!!!!!
Jimbo
Actually...
your 'Next Trick'....
should be......
SHOWING UP AT CONNECTIONS!
Good work, Bob.
How much $ is a gallon of that primer?
I have a shirt just like that!
And put some gloves on next time you sand blast!
La La Land
Danny Strickland said:
[quote="bob vawter":16ptdf7a]now for some sandblasting!
PS now i see why you have a heart problem. you must go 3 and sum change on da hoof!!!!!!![/quote:16ptdf7a]
i bet you a Fi......that i'm LESS than you Fat ASS!
Scott S.
PA
Scott
bawb you must have a pretty nice air compressor to run that sand blaster.. looks like it makes quick work outa that frame.
Bawb is probably better equipped than most of the car collision places..
ACE
Lawrence, KS
Mike Hughes
Nice work Bob. I need to learn how to weld. I got raped last time I sent a small job out to be welded.
La La Land
sorry Mike...i hope yor feelin' better........
yes i have almost every conceivable tool known to mankind EXCEPT a plasma cutter......always wanted one !
La La Land
Ron Werner said:
are your calenders up to date?
:shock:
great eye Ron...but you should know that pussy never gets outta date...but i take a close up so's you can decide!
La La Land
Does anyone wanna see this build.....or do ya jus all wanna be smart asses...................
retarded Bee keeper......was funny tho!
joe harper
florida
joe harper
If it is not too much tRoUbLe..... :?:
I personally would like to continue to be a "sMarT AsS"..... :wink:
La La Land
Next comes the TWO PART self-etching primer....this stuff is pretty much bullet-proof........
as you can see it dries to a GREEN color.....
next comes the two part Epoxy 2K primer after this....
Who do yous guys think yor dealin' wit here....
anyway?
