Okay, Mechanics..
Heart of Dixie
I drive a 99 Dodge Ram 3500 van.
Brake and turn signals are a dual filament bulb, both sides are out. Bulbs are fine. Fuses are fine. Wiring harness looks fine, the length of the van.
Taillights and backup lights are seperate bulbs and work fine.
Where do I start?
Heart of Dixie
Use a volt meter to check voltages at the bulb sockets.
If no power, it could be a ground return in a '99 due to rust conditions.
Bob, The dual filament bulbs are supplied with three wires. I presume two supply and one returns. Any idea which color is used to ground? Black, perhaps?
Heart of Dixie
The hazard switch makes the front turn signals blink, but not the rear turn signals. The turn signal does work for the front but not the rear. It does seem logical that there is a failure in the wiring going aft.
Reactions: Pioneer Floorcare
dgardner
Phoenix, AZ
Dan Gardner
According to the wiring diagram, those lamps share a ground with the license plate lamps. If they're out too, look for a bad ground.
Reactions: Old Coastie
now you know where to start....follow that wire to the t-signal switch to the hazard switch....and repair the hazard switch :D
dgardner
Phoenix, AZ
Dan Gardner
According to the diagram I found the turn signal filaments are fed from the hazard switch but the stop filaments aren't - they're fed directly from the brake lamp switch. Never say never though....
Reactions: FB19087
Although the bulbs may look good, they are probably not. Just replace them anyway and problem solved I bet. If I lose, I will buy you lunch anytime you are up this way.
Anytime, you would be welcome, we have some real treats out here. My last dodge was a 1977 motorhome and I always had problems with all the running lights. it was usually a problem with the bulbs, or the sockets. Never the fuses or the wiring.
dgardner
Phoenix, AZ
Dan Gardner
I assume you have either replaced the bulbs or properly tested them with a meter. If not, then it is a good idea to replace as Ron suggests. I have also seen several bad sockets on vehicles that use the 3157 lamps like your Dodge. Do you have a test lamp or meter?
My 2001 3500 had similar issues till I replaced the switch on the column. Replacing The computer made it run wayyy better too and fixed other electrical issues.
cape coral fl.
jack zerkie
If its only the brake lites look at the brake pedal there is a switch acuator that moves up and back as you apply the brake making the brake lites to lite jz.
Heart of Dixie
Ron was correct. I replaced all the bulbs after verifying that 1: voltage was going to the sockets and 2: the grounding block was undamaged.
Everything works fine now.
Thank you all for the very kind assistance and ideas.
Reactions: Lee Stockwell
