rwcarpet
Can the older PM's be re-plumbed with an unloader system rather than the 3 regulator setup? Anybody try this? Setting the pressure, I recall, is a PITA, and is not infinetly adjustable as the unloader valve is. I'm always changing the pressure on the Genesis according to the wand I'm using. It's as simple as turning the knob.
I'm not sure if the newer models used an unloader valve instead of the regulator system.
