ON BOARD FRESH WATER
Doc Holliday said:
http://www.tractorsupply.com/pco-tank-100-gal--2125822
100 gallon $249.00 from Tractor Supply.
But Richard...whurr would you put the ballCOCK?
M
Mr. 007
I defiantly like the lower profile ones, but again I live in michigan & this tank was FREE! shiteatinggrin It def. saves time, even if you cant make it thru the whole job u can get started quicker, I haven't done the study yet on how many gallons I use, but judging by my 110 waste tank most of my 2 rm & h Specials will be really close.
rwcarpet
Robert Hodge
Check out the sprayer tank from Northern Tool. 26 gals, 60 psi, 12 volt pump. Just plumb a fresh water inlet with a float to keep it full at job site. I like it because it will output 5.5 gpm, and it will work for those that don't want to carry 100 gals of water. And it will keep a consistant 60 psi to your water box. 26 gals gives you enough time to find a water source while you have started cleaning.
Question???....would it need an expansion tank inline somewhere?
http://www.northerntool.com/shop/tools/ ... _200394103
