- Joined
- Oct 6, 2006
- Messages
- 116,887
How many of you are using the same product for bot caret and Upholstery?
I got this in the mail from Scott W..
Although upholstery fabric protectors are similar to carpet protectors, there are some important differences.
1.
Some fabrics, especially natural fibers may bleed. Be cautious of printed patterns, deep colors, for example dark blue, deep reds, black and so forth. Some fabrics are even printed with inks instead of dyes. So, upholstery protectors must not contribute to bleeding.
2.
Cotton and other natural fabrics can shrink if over wet or slow to dry. Although rare, it may be noticed in the skirt or flounce around the bottom of a piece. Shrinkage is unlikely to occur where the fabric is held in place by frame work, sturdy foam or similar methods. Upholstery protectors should not encourage shrinkage.
3.
Upholstery fabrics, especially cushions, flex much more than carpet. Every time someone sits down, gets up or moves, the weight on the cushion is redistributed and the fabric flexes. Carpet protectors are brittle enough to break away from the fiber under all that motion. A fabric protector that can flex and remain adhered to the fibers will offer long-lasting protection.
4.
Different surfactants. Carpet protectors are formulated to protect the tuft from top to bottom. An upholstery protector needs to spread evenly across the fabric, not down into the sofa or chair.
To successfully convince your clients of the benefits of an upholstery protector, you must be personally sold on the benefits. Consider applying Maxim Advanced for Upholstery to 1/2 of your favorite recliner or sofa. See how much easier it is to clean.
Quick Guide
PROCEDURE
1.
Clean upholstery.
2.
Select appropriate protector.
3.
Check for colorfastness.
4.
Mix according to label directions.
5.
Apply with OmniPro or Pump-up sprayer.
6.
Brush protector into fibers for even application.
7.
Allow time to dwell and cure.
PRODUCTS NEEDED
Maxim Advanced for Upholstery with Dye-Loc
Maxim Fine Fabric
Handi-Groomer
Handi-Brush
Air Movers
PROCEDURE
STEP 1:
Thoroughly clean upholstery. Extraction cleaning using a tool that leaves the fabric relatively dry is the preferred method. Protector can also be applied to new upholstery if it was not sufficiently protected by the manufacturer.
STEP 2:
Decide on the proper protector for the job. Maxim Fine Fabric Solvent Based Fluorochemical Protector is available for those rare times when concerns about shrinkage call for limited use of water.
For most upholstery, Maxim Advanced for Upholstery with Dye-Loc provides an excellent level of protection from flexible polymers that maintain low surface energy when the upholstery is in use. The Dye-Loc eliminates concerns about bleeding. The protection is specifically directed at common upholstery problems like hair and body oils along with food and beverage spills.
STEP 3:
Apply according to label directions. A 6501 tip works well for most fabrics. A 6502 spray tip can be used with heavy fabrics. The sprayer should produce 35 - 60 PSI. This will help ensure that the Maxim Advanced for Upholstery with Dye-Loc and Maxim Fine Fabric spread across the fabric for even coverage.
STEP 4:
Use a Handi-Groomer or Handi-Brush to work the protector into the file. This step may not be required on some upholstery.
STEP 5:
Allow sufficient time to dry before using the furniture. Protectors will require up to 24 hours curing before they reach maximum effectiveness. Air movement ACROSS the fabric can reduce drying time.
NOTE
Many cleaners fail to inform the consumer that they can provide protector. At the completion of a job or when the client notices how wonderful their upholstery looks, simply remind them that protector can help their furnishings stay looking good longer.
Simple demonstrations using sales aids from your distributor can help close the sale.
CONCLUSION
I love the advancements in the formulating of Maxim Advanced for Upholstery. By eliminating worries about bleeding and shrinkage, we now can use a water carried fluorochemical protector for upholstery. Moving away from solvent carriers improves performance while helping the environment, reducing health risks to the technician and our customers. Certainly a situation where everyone wins.
Upholstery isn't the only place we had concerns about possible color bleed. Maxim Advanced for Upholstery is also an excellent product to use when providing stain protection to wool area rugs!
1.
2.
3.
4.
Quick Guide
PROCEDURE
1.
Clean upholstery.
2.
3.
4.
5.
6.
7.
PRODUCTS NEEDED
Maxim Fine Fabric
Handi-Groomer
Handi-Brush
Air Movers
PROCEDURE
STEP 1:
STEP 2:
STEP 3:
STEP 4:
STEP 5:
NOTE
CONCLUSION
