Oops
Boca Raton
i went down this morning to grease all the trucks fitting. I was looking at the drive shafts center bearing. It supports the driveshaft. The manual says it sealed. It's not sealed on mine. I noticed a grease fitting so I greased it. It took a lot of grease before any came out. Should I just go ahead and replace it. 105k without greasing and the rest of the drive line is every 6500 miles.
Gene.
hydracat
olympia wa
Its called the carrier bearing. They rarely just go out. you'll feel a slight shake once its worn out. I think the last one I did was 30 bucks. You'll need a shop to press the bearing into the carrier, but you may have something different than mine.
