renegade_cowboy
I was showing some friends Odins TechnoViking Electric TM... First off I gotta say that his TM are some of the best looking around.
The obvious question is what kind of suction can an electric TM create?
If you run a small generator in the van or run it off the van engine are you able to include more (6-10) 3 stage vac to equal the suction of a 20-25 HP TM?
With the TechnoViking it seems like a route more and more compaines can go with if it can create similar results of a meduim size TM.
With a LG Heater..heats not an issue and if you hook the pump up to the generator it should power the pump.
What are you thoughts...can you truly pimp these out...?
