Orangeforce123
Scott Rogers
Well I tried my free sample today, I appreciate you giving us all a chance to try the product out.
I had 2 trashed rental houses I have cleaned a few times before. I used your rental/restaurant ratios.
I was pleased with the finished product, but it didnt thrill me. One thing I noticed was my wand didnt glide as easy as with my normal presprays, had to go over the high traffic areas a bit more then my regular products. It did not dent the coolaide or pet spots.
Frankly for the soils in my area, Clean Streak (accelerated cleaning systems) does a better job and uses way less product. So for the rental/ restraunt customers I will stick with clean streak.
Thanks again, and hopefully some of the others trying it out were more thrilled.
I used mine today as well. I did one room with lots of pet stains. I mixed probably 12oz of #2 in my hydroforce just to be sure. It did ok cleaning, but didn't knock a dent in the pet stains, I used stain magic after cleaning and hopefull that will help. Like the last post stated, the solution has more of a squeek when walking on it, like the Les rubber test with my shoes, instead of slippery. Thanks for the samples.
Jim Nazarian
So. Cal
Jim Nazarian
Sample pack just arrived & it was a pleasant surprise, the packaging, containers & instructions are nicely done.
Thanks!
Lyman
Johnstown new york
Lyman
Is it to late.
lyman sweeney
12 fisher ave
johnstown ny 12095
Just in case there is one free sample pack left over.
I am not going to lie, i am shocked out of the hundreds of urine stained places that I have done only 2 have given me any trouble. Both were cat. Kook-aid comes out about 25% of the time on plastic type carpets only. If stain magic doesn't take it out neither will OF2. My goal was to have an inexpensive product to use in your pre spray to take the place of stain magic. Please use what you have left, and let us know.
PS there is a pos comment on orangeboy456
I have been getting more requests for samples. I have decided to go to 70. 40 have now been shipped.
Scott Rogers
Im not surprised. who knows what tenants did prior to cleaning in a attempt to remove the stain and helped to set them instead.
Just gave a straight up review of my experiences today with the sample provided. I dont think its a bad product. But by todays experiences my current products are a bit better and use better mix ratios.
Every cleaner in the country will run into different soils, water quality etc. so no chemical will work the same for everyone. This is way I find it important to test many cleaners to find the one that works best for your circumstances
Clean Streak cant hold a candle to Grease eraser Ive tried it twice side by side.....No freakin way.. Clean streak beats grease NO WAY!!
Scott Rogers
C Pennington said:
[quote="Scott Rogers":1qahkadq]Well I tried my free sample today, I appreciate you giving us all a chance to try the product out.
Clean Streak cant hold a candle to Grease eraser Ive tried it twice side by side.....No freakin way.. Clean streak beats grease NO WAY!![/quote:1qahkadq]
I havent tried Grease Eraser, but will give it a shot.
How ever it already has 2 strikes against it. It cost twice as much as Clean Streak and requires 30% more product for each mix, according to manufactures directions. So it better really perform well.
And like I said before. No product out there will perform the same for each user too many variables.
Jerry
I will give it a shot..
Jerry Smit
503 South Virginia St.
George, Iowa
51237
Mikey P said:
I guess my samples were sent by mule train.
:roll:
I too would love a free sample! And I won't even complain about about how long it takes to get here!
Fully Cleansed Carpet Cleaning Specialists
5A West Pursel Lane
Yerington, Nevada 89406
Charlie Lyman
Meridian, ID
Charlie Lyman
I got mine today and used it on an assisted living facility.
I was impressed with the packaging and that it even came with a measuring cup.
The brochure that came with it needs some work. Have someone go over it and proofread it for run on sentences and grammar errors, after all you are trying to sell your product with this literature.
But, I hate to be so blunt with this, the impression stopped there. I cleaned most of the home with the orangeforce and was kinda impressed. It smelled good and seemed to be doing a good job. I ran out of what was mixed in the pump sprayer, so I grabbed my HF with my regular prespray in it. I cleaned the rest of the room and about crapped my pants. I had to go back and re clean the whole room again. If I wasn't pressed for time I would have redone the whole place. I hope I don't get a call back. This is a big account.
I do appreciate your sample and the fact that you have the courage to throw yourself out here in front of this tough audience. Best of luck to you.
XTREME1
Ma
Greg Crowley
from looking at what iit has I think he over mixed his active ingredients so they dry up and should be a hydroforced down. He has som much material in it it needs the liquid to distribute it my only guess. I did use a pump up and had to rewet sunday so maybe that is it
I prespray usually with a hydroforce and prescrun with a 175 and extract and I don't do this room to room I prep and the go
Charlie Lyman
Meridian, ID
Charlie Lyman
I will use what I have left in the HF and see if I get better results. I usually try new stuff with a pump up because I want to make sure I get a consistent spray.
Bill G. Martin
Put me on the list for free samples
Bill Martin
All Pro
1113 Abagail Dr
Deltona, Florida 32725
Josh said:
:roll:
5A West Pursel Lane
let me know when Yurlintonville gets a post office and I'll send you my 8 year old bottle of Steamway Formula 0
Charlie Lyman
Meridian, ID
Charlie Lyman
How did you mix my chemicals
I mixed the chems like the paper said. I have a 2 gallon TWBS sprayer. I used 4 oz of #1, 4 oz of #2 and 2 oz of #3 in the sprayer. I double checked my metering on the rinse because I had to replace a hose on it yesterday. I set it at 4 gallons per hour.
If I goofed something up, I would like to know. I am looking for a good prespray to replace the stuff I use now.
Curt did a good job on the sample pack. If it cleans even halfway decent, I will order some product. The sample pack has enough chemicals to do 4-5 jobs. Everyone else that requested a sample should order some product. Will it replace my Powerstrike/Powerburst combo? No way. The powders and liquids smell great and I think the chems will do a great job. I can see myself using this combo on some jobs though. I did this rental with week old pb/ps combo at 4 oz each in hf. Power was off so spray and suck with less than 5 minute dwell. I believe a good emulsifier and heat will clean most residential carpets so adding this pre-spray should get good results. Again it smells fabulous. I will post pics of Curt’s product later. Prochem ps/pb combo results with no pre-scrub and limited dwell. It works for me.
Chris Muetterties said:
Live by the boards die by the boards.
just a needed a couple/three "heavy weights" to say it was great first.
Then the pack would follow.
Cause Lord knows, MOST of the guys aren't doing side by side evaluations
(or aren't cleaning dirty carpets)
Crowley doesn't have enough clout..AND he roto scrubs everything
The only way to evaluate any chem is with side by side evaluations on trashed carpets of different type construction
cut pile, loop, olie/poly and nylon
The juice you compare it to, should be the one that you have most confidence in
In effect, that's what Charles L did
