Organizing...
Numero Uno
Caesar
walmart sells these wall/ belt holders in out door area.
I used to label them per small item inside.
Then clip them to the shelves of the butler .
But most shelves would be no problem as well
The metal clips used to be on rear.
But this one is used an 20 yrs old?
But one would contain pressure wash jets,wand jet manifold palm socket ready.
Etc...
One was for the beta test greenglides kleenrite 3 inch uph tool.
But it kept items handy an techs new go get,return,everything had a place.
They cost Four bucks if Interested.
The other item was a three dollar ocean state job lot hose swivel yard stick
We kept a mesh bag in truck with pool doodle foam cut in four inch sections .
Insert solution line add foam for snug fit...
Worked like a charm .
Impressed clients,an cost nothing .
Swivel was Kool as well ,worked with you not against.
Hope it helps or promotes your own ideas...
Regards.
