Oriental Rug and Dye Bleeding
Sergio
Italy
Credits
380
Points
380
Sergio
Hi guys,
I learned very well, thanks to your advice, how to fix the bleeding of the red color. Sodium hydrosulphite and steamer! Customers are satisfied!
Now the difficulty level increases : how to fix the bleeding of green and blue colors?
Thanks!!!!
scottw
West Jordan, UT
Credits
1,777
Points
1,777
Scott Warrington
There is more difference in the type of dyes than in colors. Synthetic dyes or vegetal dyes and what fibers usually is more important than the color.
Since synthetic dyes are more common and I assume your speaking of wool and cotton fibers, start with a reducer first. The same process you might use on red.
Start with your least aggressive options first. Go stronger only if needed.
Reactions: Sergio
Sergio
Italy
Credits
380
Points
380
Sergio
Sodium Hydrosulfite fix vegetal dyes
Which chemical fix synthetic dyes?
Top
