paint overspray on concrete
Buck1955
John
Any suggestions for removing paint over spray on a new concrete garage floor? Probably 500 SF or so.
Thanks!!
a lot, a little?
Paint thinner & 0000 steel wool.
Just watch the fumes if there is a hot water heater nearby.
Thanks!!
Have you tried anything yet?
typically overspray from an airless sprayer isn't terribly difficult to remove .
By the time the fine mist (that blows back off the walls) hits the floor, it's nearly dry ..so it's not like dried/cured paint someone dripped/dribbled
a rotary with a dry red pad might get it.
if not, go green, brown or black with some water and a little soap
unlikely any solvent will be needed unless the knucklehead with the sprayer actually sprayed on the concrete and it's not just overspray mist
Reactions: Old Coastie
If it is new latex and sticking, a good wax stripper will soften it and as Ruff says, a 175 and pads will take it off. Old paint and oil-based is much tougher; use a roller to apply a water-based stripper, then hit it with pad or pressure wash. Re-apply and repeat.
jwfoulk12
Justin Foulk
I just painted my new garage with an airless sprayer and didn't cover the floor. I then removed all the overspray with flex, a 175 with a black pad and a spinner with high heat.
we just did one a month ago.
brand new CGD installed in a large open com building (2880sf of carpet)
then the moron rented a big sprayer and his inept sons sprayed the 12ft high block walls.
overspray dust everywhere
Vac wouldn't touch it
Pile brush took care of it
point is, it's not "stuck/glued " like cured paint spills or drips are
again, that's "if" it's simply overspray mist that floats in the air before settling on the floor
.L.T.A.
CTI Courtney
Courtney Rodseth
It's going to depend on the type of paint but ... A good pre-spray of Pro's Choice Firewater and agitation with a brush was more than enough to break up and emulsify almost everything except large spills.
