Any suggestions for removing paint over spray on a new concrete garage floor? Probably 500 SF or so.
Thanks!!
Have you tried anything yet?
typically overspray from an airless sprayer isn't terribly difficult to remove .
By the time the fine mist (that blows back off the walls) hits the floor, it's nearly dry ..so it's not like dried/cured paint someone dripped/dribbled
a rotary with a dry red pad might get it.
if not, go green, brown or black with some water and a little soap
unlikely any solvent will be needed unless the knucklehead with the sprayer actually sprayed
on the concrete and it's not just overspray mist
