- Joined
- Oct 6, 2006
- Messages
- 117,338
which do you use at work?
That Royal looks nice and looks durable with that handle , how's it holding up?FCC said:Cup.
Current vac:
but I get pissed off evry month or so and get a different one..........
joeynbgky said:Dirt cups are messy, have to be empied to much. And pollute the air. hear california is going to ban the sell of dirt cup vacs
The Great Oz said:Bag in the shop. We like to buy vacs that last longer than three months, so the cutesy plastic stuff is out.
On the trucks we use vacuum heads hooked to the unit. Can't pollute the indoor environment with the odor of the last customer's cat.
JB said:No a good vac is one that gets used!
The Great Oz said:We use the HP 210 - $65 from Hesco. (same as Turbocat V) We use a vacuum relief to keep from over driving the brush. You can drill a 1/2" hole in the tube as well. Guys might open the dump valve a little if they have a one-hose run.
We only have to replace them when theyre ugly from use.
Oh yeah, being PLASTIC, trying to pick up marbles might result in a cracked case. If someone would make a 210 out of metal I'd be interested.
FCC said:Cup.
Current vac:
you are assuming the soil you are picking up is going to make a noisejoeynbgky said:GET A VACUUM WITH A BAG! WHY DO YOU WANT TO WASH AND REPLACE THOSE CHEAP HEPA FILTERS? YOU SAY YOU WANT TO MONITOR WHAT ITS PICKING UP? USE YOUR EARS AND LISTEN, AND LOOK DOWN. oops caps was on:!: :!: :!: :!:
Nate The Great said:[quote="The Great Oz":1e4cy5ka]Bag in the shop. We like to buy vacs that last longer than three months, so the cutesy plastic stuff is out.
If I can fill an inch in a canister within a 4sf area, what is that going to do to a bag?
Ron Werner said:you are assuming the soil you are picking up is going to make a noisejoeynbgky said:GET A VACUUM WITH A BAG! WHY DO YOU WANT TO WASH AND REPLACE THOSE CHEAP HEPA FILTERS? YOU SAY YOU WANT TO MONITOR WHAT ITS PICKING UP? USE YOUR EARS AND LISTEN, AND LOOK DOWN. oops caps was on:!: :!: :!: :!:
even light sand doesn't make much noice
latex powder, deodorizer powder, fine soil, dust, dander, hair, gyprock dust, none of this makes a sound yet you can fill a canister with this stuff really fast
How would you even know to keep vacuuming if you ran into a room with this:
this is 1 of 14 canisters from a 200sf room, mostly deodor powder, their was no visible soil on the top of the carpet. Filled this canister from about 10-15sf.
I thought I was too, until other guys started using similar vacuums and began posting what they got out.JB said:Dude I luv ya but YOU are the ONLY one that can/will do that!
One of the things that allows growth is an ability to analyze and properly attribute costs. Another is to recognize the cost savings of efficiency in reducing labor effort and time spent on the job. The cost of fuel is relatively small next to the cost of labor, and I'd be more concerned (if it mattered) about hours on the unit.Isn't that a gross waste of fuel? That surprises me that a multi-trucker like yourself would use one of those. Of course id surprises me that your guys vacuum too...
that I conceeed to.I am a dirt cup type guy. I think its a great visual aid to help sell our services.
Once you've seen what comes out of the carpet, you won't think it so weak. Then you can tell them about the colour change as you steam cleaned the carpet, or OP or whatever. I've been in too many places where had I not been able to see it coming out, it would have remained there. I've gone into homes, already prevacuumed, NO indication of any soil in the carpet what-so-ever, and I pull out a canister of soil.JB said:that I conceeed to.I am a dirt cup type guy. I think its a great visual aid to help sell our services.
the argument i don't buy is
"how do you know what your pulling out if you can't see it?"
I call BS on that one, how do you know when your super sucker TM did it's job if you wanna use that argument... it's a weak argument at best.
Mrs. Pilfington... "So JB did you get a lot out?"
and the answer is.... :?:
