Okay just a update
I have been using Parker Parflex over this last week. The heat is without a doubt better, I am staying at a consistant 200-210 ATW at @120 of Parflex.
I am going at a much faster rate just because I am so busy this week, all empties, I know the temps will get a little hotter on my resi work when it is not so blow and go.
I made a error in my post earlier I thought my TM gauge Numbers were higher on the gauge, it
tops out at 240 not 250. My TM is staying between 200-230 mark and stays in that range probably about 220 as my wand today was popping almost all day. I put a lie detector on wand for a while to just check it every time I looked at it, it was @ 205+ it is kinda bulky so I took it off after a couple rooms.
I can say the hose ACTS much different than goodyear type hose (steel/rubber) it is much less flexable or I should say it doesn't lay the same, well at least not in these units I have been on this last week very cut up inside. They are just a pita to work in Townhouse/condo type.
I started out putting it on my hose reel but it does not come off the same as steel braid either.....very noticable on the first job when it is cold, but I have found it coils up fairly easily and because it is SO LIGHT, I kinda prefer to just loop it and set it in the back of the van.
So as of now I am SUPER happy with it, the nice light weight, and added heat has just made my PC Legend a little better. I always figure eighted my solution hose on the way out of the job back to the van anyway just made spooling my hose up on the reel easier, so being able to coil this up and set it in the van so it is ready for the next job is okay too.
So thanks Mikey for the suggestion super happy with it, now I just have to wait and see how long it lasts
So if any are trying to get a little more heat, the Parker Parflex does seem to help with that.
