what are your mixing ratios... 2-4 oz. per gallon of water ???Jim Martin said:sometimes....
i have used the Search button... But cant find anything on how much to mix...Mikey P said:
AshleyMckendree said:It will turn your skin chalk white and tingle like a mofo, too.
dave105 said:For you guys using the Sallys 40 volume, does it matter if its a cream developer or clear?
Mikey P said:Know what your HF is producing RTU and then add 2 to 4 ounces per.
Mine makes about 6 gallons of mixed juice so I add 6 ounces of 40 vol.
A peroxide boost helps loosen up urine, coffee and other protein spills. Also helps deodorize. Brightens colors as well. And as a extra added bonus, it burns the fat right off your skin so you don't have to think about what a broke dick you are for the next 20 minutes.
This boost can be applied to any color carpet or white only carpet? What's the limitations? I read the other thread you posted but seen nothing of it.
