peroxide vs bleach
Chads
This was forwarded to me today in a e-mail.
Hydrogen Peroxide vs. Bleach
This was written by Becky Ransey of Indiana (a doctor's wife), and I want to share it with you. She was over recently at a friend's home for coffee and smelled the bleach I was using to clean my toilet and counter tops. This is what she said: I would like to tell you of the benefits of that plain little ole bottle of 3% Hydrogen peroxide you can get for under $1.00 at any drug store. What does bleach cost?
My husband has been in the medical field for over 36 years, and most doctors don't tell you about peroxide. Have you ever smelled bleach in a doctor's office? NO!!! Why? Because it smells, and it is not healthy! Ask the nurses who work in the doctor's offices, and ask them if they use bleach at home. They are wiser and know better!
Did you also know bleach was invented in the late 40's? It?s chlorine, folks! And it was used to kill our troops. Peroxide was invented during WWI in the 20's. It was used to save and help cleanse the needs of our troops and hospitals. Please think about this:
1. Take one capful (the little white cap that comes with the bottle) and hold in your mouth for 10 minutes daily, then spit it out. (I do it when I bathe.) No more canker sores and your teeth will be whiter without expensive pastes. Use it instead of mouthwash. e.g. Arm & Hammer baking soda & PEROXIDE.
2. Let your toothbrushes soak in a cup of peroxide to keep them free of germs.
3. Clean your counters and table tops with peroxide to kill germs and leave a fresh smell. Simply put a little on your dishrag when you wipe, or spray it on the counters.
4. After rinsing off your wooden cutting board, pour peroxide on it to kill salmonella and other bacteria.
5. I had fungus on my feet for years until I sprayed a 50/50 mixture of peroxide and water on them (especially the toes) every night and let dry.
6. Soak any infections or cuts in 3% peroxide for five to ten minutes several times a day. My husband has seen gangrene that would not heal with any medicine but was healed by soaking in peroxide.
7. Fill a spray bottle with a 50/50 mixture of peroxide and water and keep it in every bathroom to disinfect without harming your septic system like bleach or most other disinfectants will.
8. Tilt your head back and spray into nostrils with your 50/50 mixture whenever you have a cold, plugged sinus. It will bubble and help to kill the bacteria. Hold for a few minutes, and then blow your nose into a tissue.
9. If you have a terrible toothache and cannot get to a dentist right away, put a capful of 3% peroxide into your mouth and hold it for ten minutes several times a day. The pain will lessen greatly.
10. And of course, if you like a natural look to your hair, spray the 50/50 solution on your wet hair after a shower and comb it through. You will not have the peroxide-burnt blonde hair like the hair dye packages but more natural highlights if your hair is a light brown, faddish, or dirty blonde. It also lightens gradually, so it's not a drastic change.
11. Put half a bottle of peroxide in your bath to help rid boils, fungus, or other skin infections.
12. You can also add a cup of peroxide instead of bleach to a load of whites in your laundry to whiten them. If there is blood on clothing, pour it directly on the soiled spot. Let it sit for a minute, then rub it and rinse with cold water. Repeat if necessary.
13. I use peroxide to clean my mirrors. There is no smearing, which is why I love it so much for this. I could go on and on. It is a little brown bottle no home should be without! With prices of most necessities rising, I'm glad there's a way to save tons of money in such a simple, healthy manner! "This information really woke me up. I hope you gain something from it, too.
harryhides
Canada
Tony
HOME USES OF HYDROGEN PEROXIDE – H2O2 www.welnesstoday.com/october
This inexpensive liquid in the brown bottle can save you plenty of $$$.
Oxygen is the most abundant element on earth, comprising 45.6% of the earth's crust and 20.95% of dry air, and is one of
the most vital elements to support life for plants, animals and man. Hydrogen peroxide has been sold in drug stores for
many years as an antiseptic and a bleach. With a cost of less than .60 cents per 16 oz. bottle, it is one of the world’s
great "miracles" in a bottle.
Although it is not approved by the FDA or medical profession to be taken internally, it has many uses in homes, farm and
garden. How many have you used?
Use 3% hydrogen peroxide in chilled water for washing chicken or other poultry and beef or pork.
Cleansing for vegetables and salad greens: Add 1/4 cup 3% hydrogen peroxide to a sink full of cold water.
Wash vegetables thoroughly, rinse with cold water and drain. This process prolongs freshness.
In the dishwasher or dishwater: Add 2 ounces of 3% hydrogen peroxide to the regular washing formula.
Your glasses will sparkle!
Marinade: Place meat, fish or poultry in a casserole (avoid using aluminum pans). Cover with a diluted
solution of 3% hydrogen peroxide. Place in a loosely covered container in refrigerator for 1/2 hour. Rinse and cook.
Leftover tossed salad: Spray with a solution of 1/2 cup water and 1 tablespoon of hydrogen peroxide.
Drain, cover and refrigerate. Eliminates use of chemical preservatives.
To freshen kitchen: Keep a spray bottle of 3% solution of hydrogen peroxide in the kitchen.
Use to wipe off counter tops and appliances. It will disinfect and give the kitchen a clean, fresh small.
Works great in the refrigerator and lunch boxes.
Humidifiers & steamers: Use 1 pint of 3% hydrogen peroxide to a gallon of water. This helps keep them clean too.
Laundry: Add 8 ounces of 3% hydrogen peroxide to your wash in place of bleaches.
Shower: Keep a spray bottle of 3% hydrogen peroxide in the shower.
Spray your body after washing to replace the acid mantel on your skin that soap removes.
Rejuvenating Detoxifying Bath: Add 6 ounces of 35% hydrogen peroxide to a tub of water.
You may increase up to 2 cups. Soak at least 1/2 hour.
Alternate Bath: Add 1/2 cup 35% hydrogen peroxide, 1/2 cup sea salt, 1/2 cup baking soda or Epson salts to water and soak.
Foot soak: Add 1 & 1/2 ounces 35% hydrogen peroxide to 1 gallon water and soak.
Pour a capful of 3% hydrogen peroxide in each of your ears after swimming to prevent ear infections.
Use 3% grade as an astringent on your face, neck and full body after bathing. Gets rid of acne FAST.
Use it in 3% grade in a spray bottle for cuts and soars. Spray on frequently and watch them disappear.
Use it as a douche in 3% grade.
Athlete's Foot: Soak feet nightly in 3% hydrogen peroxide until condition is improved.
Mouthwash: Use 3% hydrogen peroxide. Add a dash of liquid chlorophyll for flavor if desired.
Swish it around in your mouth for 1-2 minutes before brushing. Watch how white your teeth become!
Toothpaste: Use baking soda and add enough 3% hydrogen peroxide to make a paste.
Or, just dip your brush in 3% hydrogen peroxide and brush.
Toothbrush: Soak your toothbrush in 3% hydrogen peroxide between brushings.
Pets: For small animals (dogs and cats) use 1 ounce 3% hydrogen peroxide to 1 quart water for their drinking water and bath.
House & Garden Plants: Put 1 ounce 3% hydrogen peroxide in 1-quart water. Water or mist plants with this solution.
Sprouting needs: Add 1 ounce 3% hydrogen peroxide to one pint of water and soak the seeds overnight.
Add the same amount of hydrogen peroxide each time you rinse the seeds.
Shorty
Cairns
Shorty Glanville
To add to Harry's list:
I have used peroxide to clean my open wounds, scratches, etc;
I also used to use peroxide to bleach my hair.
Some time ago :oops:
Ooroo,
:roll:
