pet stains
just cleaned a trashed carpet for a property owner i do some work for, anyways used 02 system sprayed heavy still noticing yellowish stain from pet urine, so used pros choice urine stain remover as an after spray so it can continue to work as the carpet dries if the stains are still there after a couple of days what can i do next?
topnotchman
depends, if the USR worked, if it improved, I would try it again let it dwell for another day or so. Or use a different product Stain Magic, tannin remover, etc.
DevilDog
You just have to experiment with these things...there is a good chance the stain will NOT come out. Between each application make sure you rinse well.
Try another dose of Stain Magic.
Try some coffee stain remover.
Try some acetic acid.
And close to acetic acid is vinegar.
Urine can be very damaging to carpets...sometimes nothing works.
tim
todd is right but there are a few tips on "stain magic" to remember.
1. make sure area is rinsed from other cleaners, etc.
2. get the area as dry as possible
3. treat with properly mixed stain magic, stain zone or use 40 volume with some ammonia as an accelerant
4. add steam (in very short tests, careful not to bleach)
5. alternative to steam is a DCI light left on overnight, much safer
6. bonded insert- chances are, if this doesnt work, get out the carpet knife
juniorc82
Jefferson City missouri
Jon Coret
I use the pros choice usr have always had good luck . what I do however is after I spray it on I cover with plastic to seal in the urine stain remover seems to work better. tell the custy to rmover in 24 hours
