I have a couple questions those of you who use this might be able to help me with.  I liked the idea of this product because it is combining to methods of attacking the odor in one product, the oxidizing powder, plus hydrocide at the same time.
First I am wondering if it is "ok" to use the hottest tap water I can get, which I'm guessing is usually in the neighborhood of about 120 deg? as the directions say it's best to use 160+. I have no way of getting the water this hot at custy's home.
Today I mixed up a gallon of this product, and poured the entire gallon over one stain approximately 8" by 18". I figured that was overkill but wanted to be sure it got down into the pad. I then treated the stains in the other rooms, etc. Setup my steamin demon and by the time I flushed the area with the demon it had been over 30 mins. I flushed it really good and then did many very slow passes. Before leaving I bent down to smell the spot and it still smelled like pee.
Does it need to dry before the odor will be gone or did I do something wrong? If this product "needs" to have water of 160 degrees or more and I can't do it I guess I'll need to find another product to use.
