steve g
I post this here because it will get more views and most CC guys do have a little bit to do with WD work at some points in their lives, a couple weeks ago I bought a used drieaz 2000 LGR, the first job I set it on was a fairly typcial loss, however I noticed it substantially dryer than I thought it would normally be given the time and conditions. keep in mind I have been using phoenix 200 Max's as my front line dehu for the last few years. anyways today proved what I had been thinking both dehus setup in the same room proved the tale, room conditions where 82 degrees 30% RH for a GPP of 49. drieaz lgr 2000 output 100/11.2 for a GPP of 32.25, the phoenix model output was 103/11 for a GPP of 35, doesn't sound like much of a difference well it is considering the drieaz is putting out 320 CFM vs 265 for the phoenix. the drieaz is kicking out 20% more air that is dryer to boot!!!!!!!! the drieaz is rated at 110 P/day AHAM the phoenix is 130 p/day AHAM. I am starting to think these specs are pulled out of someone's butt. the drieaz stomps the phoenix unit so bad. I don't see myself buying another phoenix unit again, I don't like lieing about ratings. xactimate just lowered the rental price for the drieaz 2000's to 71/day since phoenix lied about its ratings they still pay 104/day, so I get less money for dehu that performs better, wonder if drieaz sells just the 2400 LGR stickers by themselves, so I can make all my 2000's into 2400's.
