- Joined
- Oct 9, 2006
- Messages
- 64,833
- Name
- Rico Suave
LOLThe big open glide that's on my Mach. Not the dildo looking glides
Its ok to be wrong as long as you're not intentionally wrong!This subject has come up in the past, and I never found a solid answer to which way was the best
When I first started cleaning carpet, I had a prochem quad without a lip glide. 3years later, I learned my lesson. I bought an 802 with the black colored glide. It was a little better. Then I got the dildo glide to put on my prochem quad, and it was too easy. So easy, I was paranoid that it wasn't sucking up half the water it should've. Then I put a single lip glide on it. It got better. then came the mach15. It is so easy to push compared to a prochem quad without a glide, that tells me that I've learned my lesson, even though I hunch over like a troll, lolOk Matt, looks like you're going to learn the hard way. You remind me of me at your age...that's not all good ;-)
Don get stuck. ...Play nice fellas!
I have work to do, 6 acres to cut this afternoon. Later!![]()
I don't understand why he's starting to mowe 6acres of grass in the afternoon. What the hell is he thinking doing that in the heat of the day?Don get stuck. ...
Thanks Ron. You're a good guy, no matter what Mikey tells me.Everybody has their own techniques and there is no absolute right or wrong. I use the handle on the wand to crack it slightly on my forward stroke. This allows me to start the stroke without the wand being sealed to the floor. It also clears the wand and hose of water and foam. You are doing good work Matt, just look for ways to treat your self better. You'll be thankful when you're older, not needing surgeries or other treatments.
Hes mexican.I don't understand why he's starting to mowe 6acres of grass in the afternoon. What the hell is he thinking doing that in the heat of the day?
I love the heat. I love mowing. Crank up my music and cut for hours and hours.I don't understand why he's starting to mowe 6acres of grass in the afternoon. What the hell is he thinking doing that in the heat of the day?
I am? Why didn't one of you fookers tell me?Hes mexican.
Inconsiderate SOB!The neighbor mows around the pond and from his property to the pond but nothing on my side.
I can't imagine why?
Shit stirrerThanks Ron. You're a good guy, no matter what Mikey tells me.
Reeko would need a couple of donkeys to protect the herd and that visual would hit too close to home.I have no idea why someone would mow 6 acres when they could let a cow eat that stuff...
I cut 4 more today. It grows to fast for the horses to maintain it on there own. Its been two months since they needed help. Around the house needs it weekly when we have rain. Normally by now the sun starts to burn it up but its been so wet, it looks like spring.I have no idea why someone would mow 6 acres when they could let a cow eat that stuff...
We know why Reeko doesn't have sheep--- He is famous for his quote "Mutton's better than Nutton"
i'll have to take your word on that one!
