Pink spot
richd8980
sprayed pre-spray as I alway do didnt notice any spots, then when extracting notice a few pink spots. I have seen them before on
other jobs. Not sure if I I had something mixed in my prespray or what? Any thoughts as to why pink spots happen?
be patient, someone will help
a little more info would be helpful too
what pre-spray and what fiber type carpet
My thoughts are running along the lines of acne ointments.
When dripped on the carpet, they don't do damage til water is added.
The "pink" you're seeing my just be some of the color that wasn't bleached out
any teenagers in the house?
Willy P
Vancouver
Willy P
Sounds like bleach on polyester. It always leaves a pink spot when it gets bleached.
Johnny
La-Z-Boy
Johnny
"Ph shock" from high alkali. (High ph prespray, booster, bleach, etc.). Sometimes reversable with an acid (acid rinse, rust remover, citric acid, white vinegar, etc.).
richd8980
If its because of high ph why doesnt it do it all over the carpet? Why only certain spots?
Thanks for the replies
Johnny
La-Z-Boy
Johnny
Could be spots previously treated by the homeowner or another cleaner. You added your juice to theirs.
STEVEC
Could be something as stupid as Nerds ( candy ) that were at the base of the fibers, candy dye bled and wicked up as it dried. Had that happen before.
Torn
San Diego
Chris Thomas
That's happened to me more than once. I almost like those as much as I like airsoft pellets...........
