Pit number #2
#1 is to the left and lots of flat, clean concrete for dusting, HWEing and what not to the left.
rhyde
rhyde
Kind of a small pit don’t you think?
You’re going to wish you didn’t put that expansion joint there in about a year
The walls will have a water proof dry wall about 4 feet up.
The 17 x 15 pit is out of the frame.
This is the small one.
Steve, you need to up the strength of your Dr Dean Edels.
There is a sump pump hole right that there.
daniel@procarpet
How does the pit fill with water if there is a hole in the bottom? If you plug the hole, wont any rug you place in the pit be sitting in dirty or urine filled water? I know the general idea is to have a river effect with clean water coming in and the dirty water going down the drain hole. How much flow can you get in a pit like that, and what do you use to pump water into the pit? A waterhose?
Hole, not drain.
A sump pump fits in the hole.
Turn off the pump and the pit fills up.
GRHeacock
The waste water is pumped out, and sent where?
And how do you hang them?
Gary
rhyde
rhyde
I used cement board for bathroom tile work as a backer it works very well
Gary
Into the sewer system Gary where else?. I'll show some pics of our drying room later.
R W
Mike....where did you set this up? It's not at your house, is it? Or are you renting or buying the property?
Shawn Forsythe
Like Randy, I am surprised that a Tree Hugger would put an expansion joint in a wash pit.
Waste of a lot of money! My pit that I made only cost $68 dollars and I can break it down
if I need more room.
Remember not all rugs need to be pit washed!!!
I only do the urine soak rugs .
Looks good!
edit: got yelled at for being a dick.
doesn't mean some aren't clueless.
Bob Savage
Bob Savage
Mikey,
If your talking about the green drywall, it is water resistant, NOT waterproof.
I would do as Randy suggested. Use cement board, thinset and tape the joints.
That is water proof!
