Many trucks I've seen always have a slide-in unit facing either out a side door or a rear door. I'm sure it is to work the engine but am equally sure it is to suck the fresh air into the engine to cool it down. But what if the van doors or box truck doors were to close, providing all exhaust has been diverted to the outside, and in theory, there are no exhaust leaks, is it possible to run a machine in a closed area?
I am looking at a Roto Rooter step van that is all aluminum, sides and floor. It has an on board generator, which I don't need but has exhaust ports to the outside. If I were to position the machine inside, what could be the downfalls or dangers by running a slide-in unit.
I would also have to redirect my waste tank and blower configuration whereas the tank is about flange has a hose parallel to the blower with an 18" hose. If I added a 90 to it I can move the tank to the side of the machine and not directly in the rear.
Any thoughts on that?
Thanks for any suggestions,
Eric
Eric
