Please advise me on the best way to clean the carpets in this building.
Building is sixteen stories high.
It is a completely sealed building.
Unable to run hoses down the exterior of the building.
Access is only from the front street.
You cannot run hoses through the self closing doors across the foyer to the fire escapes.
The fire escapes are alarmed and cannot be used for any maintenance work.
There are no other stairwells in the building.
If the vehicle is under 6.6" high, you can drive up to the second level.
This is where you can also enter the lifts/elevators.
Most carpet is direct stick polyprop carpet tiles.
The air conditioning is turned off after hours.
To have the air con running after hours, there is a $300.00 per hour surcharge.
I have two levels to clean, 11 & 13.
There is also no hot water available and the heat/fire sensors are VERY sensitive.
What equipment would you use and how would you do it ??
Thanks,
Shorty.
Thanks,
Shorty.
