Larry B
What is the best UP tool out their????
Thanks in advance
Thanks in advance
Art Kelley said:For the money you can't beat an internal jet PMF tool with the trigger guts removed so it becomes continous flow. A valve permanently attached to the whip to slow the high pressure water flow to just the end of the tool allows you to quickly change from your carpet wand to clean a piece of upholstery. I've used this for years now with great results. It's a fraction of the cost of a specialized tool like the DriMaster and is built like a tank.
Oh, and put some teflon lips on it so it becomes a wet dream.
Shane T said:[quote="Art Kelley":2i13p25t]For the money you can't beat an internal jet PMF tool with the trigger guts removed so it becomes continous flow. A valve permanently attached to the whip to slow the high pressure water flow to just the end of the tool allows you to quickly change from your carpet wand to clean a piece of upholstery. I've used this for years now with great results. It's a fraction of the cost of a specialized tool like the DriMaster and is built like a tank.
