Wandslinger
It stopped working yesterday and I can't figure out why. No noise no nothing. I took it apart to make sure nothing was lodged in the impeller and it's clear. I tested the line using a meter and definately getting 12 volts to the waste tank. I then cut the wire to the flow switch and tested it and getting about 8 volts. Not sure what to do next and I'm stumped. Bad flow switch or pump? Any suggestions would be appreciated. Thanks
