- Joined
- Oct 7, 2006
- Messages
- 10,878
- Name
- Jim Martin
Gave the Martinized pool filter a good test today.................
DID NOT vacuum this place at all wanted to fill the filter as much as possible...
I hooked it up to the truck to a "Y"
double 50' from the truck and 65' from the filter into the home...
( as we all know as 4 to the door).......
before I started I was pulling 391.1 cfm's.... air temp was 90.1 degrees
after I was finished ....I was pulling 380.8 and the air temp went down to 89.7
cleaned the house and filled the filter about half full....Notice how it balled at the end and left the sides open for air flow..( the little ball is what I cleaned off the top and dropped in)
with the filter apprx half full with this set up I lost approx.....11 cfms
mind you this is with out pre vacuuming.. normally I vacuum every house and I can go all day with one hose liner and I am sure my cfm loss is less then that........This is my house I cleaned and I have been watching how it dried..in 2 hours my entire house was dry....there was no difference from the first room to the last.......I think this is going to do OK.....
