How many of you guys are using, or have used a high powered portable system, such as the Recoil as a truckmount. I've heard you can keep the whole system in the van and use a generator to power it and propane for heat. Then by adding additional solution and recovery tanks you can be fully set-up from the vehicle supposedly up to 150 feet.
From someone who is using a portable everyday, in/out of the vehicle, up/down stairs filling/dumping/refilling...etc this system sound very interesting and much less costly than even an entry level TM...BUT I know theres pros & cons to everything, so I was hoping for more info on this type of set-up from those of you in the know.
Thanks again, this board continues to be a great help to me!
