I have a old HydraMaster aqua-cat with 1000hrs that has exhaust exchanger. With my 4 jet wand with 12 flow the heat will not even maintain 100 degree's . But when using my 1 jet upholstery tool it stays at about 190. Can I add my little giant heater to this to get the heat I would like? The reason I am not sure is because of the hot water dump thing that goes into the waste tank? Also in the manual for this truck mount it says that is suppose to run at a max of 12" of lift yet It has been running at 15" of list with the hose capped off if this something that is not good for the truck mount? Can I adjust the vac relief to get it to 12" I have never messed with a vac relife before so I am kinda clueless on this one.
Thanks for any opinions in advance.
Jamie
Jamie
