H
hanks75
I mainly do rentals and residentials. The residentials can be tough at times. Which prespray would you go with?
TimP said:Buy both and find out.
James Cooper said:Yep , Cobbs stuff is really good, nice fresh scent too.
TimP said:James Cooper said:Yep , Cobbs stuff is really good, nice fresh scent too.
The only problem with powermax is that it's not Inline sprayer friendly.
Like I said try it all make your decision.
joey895 said:TimP said:James Cooper said:Yep , Cobbs stuff is really good, nice fresh scent too.
I use powermax in my inline. Is there something I should know?
I add it straight to the jug, fill with hot water, shake it up on my way into the house and I've never had an issue.
TimP said:It clogged my filter up. I think if you dilute it down it might be ok. But no way you're doing 40 oz in a 5qt jug. That's 4oz to a gallon.
All I use is 6 oz of powder redline in my 5 quart with yellow tip and it kicks power strikes ass.
Jim Martin said:All I use is 6 oz of powder redline in my 5 quart with yellow tip and it kicks power strikes ass.
where do you get this stuff......
meAt said:Jim Martin said:All I use is 6 oz of powder redline in my 5 quart with yellow tip and it kicks power strikes ass.
Redline is a Masterblend product, Jim.
It's a pretty darn good pre-spray, but ain't no way in hell it'll cut it on on a soiled carpet at the dilution Dan uses...
maybe that's why Dan is moving toward more bonnet and encRapping?
I wouldn't be surprised he's getting just as good or better results with spray 'n wipe or dirt grinding
cause he's not pre-spraying with much more than conditioned water....
danielc said:At 6 oz in the hf it comes out nice and white. In a pump sprayer I mix 1-2 oz per gallon.
danielc said:Jim you have been more than fair with me.
I am going to send you a jug of Redline.
Mix three two oz scoops in your hf. I use a yellow tip. I know that is insanely low, but it cleans great and even filthy carpet.
If you encounter a really bad dog pee carpet etc, add some citrus and OSR.
You will like it for sure. I have been more than impressed with all the Master Blend chems.
I use an enzyme such as powerburst for protein soiling etc. Using one on residential is not a good idea imo.
There is almost no smell, it mixes easy, very cost effective, no butyl, and it works.
Tim Powerstrike is 12 oz so the redline is half. All the presprays I have used except one I won't mention have done a good job. I just prefer this for residential. At 6 oz in the hf it comes out nice and white. In a pump sprayer I mix 1-2 oz per gallon.
I tried a sample of soap free and really liked it, but I have a ton of dry slurry and mix 8 oz in my 5 gallon jug just to have a little surfactant in the rinse.
h]http://www.youtube.com/watch?v=JbQKpxeCwUsh]
Just following the directions on the label Larry.meAt said:Jim Martin said:All I use is 6 oz of powder redline in my 5 quart with yellow tip and it kicks power strikes ass.
floorguy said:hummm my last 2 orders where soft and fluffy...
Whats going on Larry??
i need to order again sooo
