adamh
I have a problem with this Powerclean unit that I cant figure out. What is the number of a Powerclean guru?
thanks
thanks
The problem is this.
After this thing heats up, if you put the wand down for a little bit the pressure starts to climb. It will go from 500 psi to 2000 psi in about 1 min.
I have changed the temp sensors, and the pressure regulator.
I have checked and rechecked everything. .....
Yup. The service manual pdf I have has nothing.No one has a plumbing diagram on the genesis.
