JFRASER said:
I own a powermatic 2100 and it pulsates off and on. I have modifided it some by removing the stock chem tank. I also have changed pulse hose to standard 3/8 hose from pump to gauge, Steam Way said this should not make a differance. I have tryed everything, when I force water into system the pulse stops. Can anyone help me?
what's a "pulse hose"?
and what "pulsates" off and on?
the pump?
"when I force water into system the pulse stops. "
you mean when you unplug the water box at the plenum and drirect connect a garden hose there?
if so, plug in, turn the water on, but leave the TM OFF.
Look for water leaks.
If you see any, that's a air leak when the TM is running and that's why your pump is pulsating.
side note.. curious why you removed the chem tank?
and did the pulsating probs start after you removed the tank?
