dmirf1@msn.com said:
Looking to buy new sprayer. Opinions on what you like please. My 3m corded is getting old. I am going to repair it for a back up. I have looked at Master Clean and am leaning that way.
What models are you using and why.
ever since Hf discontinued the BEST "all around" sprayer ever designed in the HISTORY OF THE WORLD...
this one;
http://www.vacuumcleaners.net/vacuum_cl ... _1143.html
and went to that goofy Omni-thAng..... :roll: , instead of making just a few design changes that would of made the original one the
PERFECT sprayer .....I'm in quandary what our next sprayer will be.
I don't want a sprayer the size of a small porty :roll:
But I'd like more capacity than 2 gal (Multi-Sprayer)
i keep rebuilding and repairing our original HF cause there are none better on the market .
It's starting to look a little rough, and I'd of replaced it a couple/three years ago with a new one...but you can't find them anymore ..... :x
The Multi-Sprayer and the original HF electric are ("were" in the case of the HF) the two best sprayers
EVER.
The Multi's only real drawback is the 2 gal jug .
Not only the capacity, but the small mouth on the jug makes mixing powders a bit of a PITA
The "sweet spot" for us is 3 gal
We need an industrious fellow like Joe Brister to see if he can resurrect the original HF design.
3 gal capacity , HUGE/WIDE opening to mix powers, ability to set in a 1 gal jug when needed .
Just incorporate a couple design changes ..like a vertical holder for the wand and rocker switch instead of the toggle that BEGS to get busted off
You reading this thread, Joe??
