- Joined
- Aug 11, 2012
- Messages
- 13,372
I just picked up 150 ,ft of the hydro force. I have another 50 ft lead hose of the same that I will change out more frequently.
Blue is hard ot come by, Ask Olson or Cobb if they can get it.
For some strange reason it s a bit more flexible than the orange.
John Olson's price is Stupid high on just a 50ft hose. I'll buy a continental again before I spend that much on just a 50ftJohn Olson carries Blue
Larry Cobb has Orange
I agree that the blue has slightly more flexibility to it.
Color doesn't matter, but most any synthetic hose made for carpet cleaning will last far longer than steel. Even when it breaks down and starts to leak, it doesn't leak impossible to remove color. Roll it up with your vac hose or hang it on straps. It only has a coil retention issue if you force it onto the tiny reels designed for steel braided hose.ignore anyone who tells you to buy anything but Parker Parflex 1035HT in Blue.
We use a short "lead whip" of 1/4" line because all of the failures
I think he posted they use 3/8" hosesWhat size is the rest of the run?
The Goodyear has been reliable but all steel braid hoses can get hot enough to leave permanent welts on polypropylene (olefin) carpet.
He deserves some ball busting. When you don't return a call from a customer with a problem, the customer boils on it, even 3 1/2 years laterHad that happen ONCE, parker was on the way the next day.
This should be reason enough to use it....
180 from Larry, maybe more for YOU for busting his balls.......![]()
Its a lesson for us all.He deserves some ball busting. When you don't return a call from a customer with a problem, the customer boils on it, even 3 1/2 years later
