Pressure issues
Kevin B
Kevin Bunce
Curious as to your guys opinion. I have a maxx 470, cat 3cp pump. Yesterday, out of the blue the machine just didn't build pressure. After a minute, up it came and we finished the job. Today, it did same thing. When I run it with a male qc plugged into solution hose pressure drops down to 100ish or so, in order to get working pressure of 300, I had to have pressure up to 600. Is this check valves or pressure regulator? Neither have ever been touched. 4100 hours
I would lean more towards check valve is stuck or broken spring.......
Dan
Dan
Unloader or check valves.
Jim Williams
Jim Williams
It could be sucking air in. Either a fitting or the pump seals need replacing. Or a stuck unloader.
Kevin B
Kevin Bunce
Seals were done this winter, it's not sucking in air.
Dan
Dan
Im still going with unloader as my first thought. Have you tried adjusting the pressure on it when not priming?
alazo1
Albert Lazo
Well, I was going to say seals but you said you got them done. I have the same unit as you and had the same problem a few months ago. It was the seals.
Kevin B
Kevin Bunce
When not priming? If I crank regulator all the way up, it goes to 150. I have had the best luck cycling the pump on and off. I think maybe a check valve stuck open and eventually works well enough to build pressure.
Dan
Dan
Should be easy enough to check. Generally with the unloaded when they screw up they always run pressure and don't bypass. Believe it or not I have never had a check valve fail me.
Kevin B
Kevin Bunce
I have had unloaders stick in bypass, but they were the cheapo all brass units.
I still don't know if this cat pump has 3 or 6 check valves. The chemical pump has one, and it's mounted on the lower hex heads. I guess I will just start trouble shooting
it's probably the magnetic pull of the moon
If you have air getting into the supply side you will have symptoms just as you described. Same with restrictions like clogged inline filters on the supply side.
So its not exactly a crazy idea...........
Kevin B
Kevin Bunce
My experience is air into the supply side, creates cavitation and erratic pressure fluctuations. Point taken and I will check for that, but I feel it's more of a regulator/check valve issue myself. I just didn't feel like pulling check valves if its regulator. :)
