Out of Character - 0
- Joined
- Feb 8, 2007
- Messages
- 1,660
- Name
- Jesse
I bought a new pressure regulator/unloader and for some reason it works like both?
I tested it after install and it worked fine. I set the pressure and then it would drop about a little when keying the wand.
Tonight when we started a kitchen job it was working the same as always. After a couple hours I dumped the waste and started it up again. This time I could hear the pump running but the gauge showed 0psi. One of my guys started cleaning while I was looking at the gauge and the pressure would rise only when the wand was triggered. I tried different pressures and it kept running the same way. 2 Hours later I went to shut down and dump again, it had switched back to holding pressure and dropping a little when keyed. When I started it again there was no change.
Anyone know what's up with this thing?
