jstucky
- Joined
- Sep 12, 2008
- Messages
- 451
- Name
- Jordan Stucky
So...argued with my dad today again..I think I'm right but it's hard to argue with a guy that says he's cleaned carpet for 30 years blah blah blah..telling you that your wrong....I had a ServiceMaster franchise blah blah..
but dad I've got Mikeysboard and you don't! and never have..ha
So bear with my stupid questions and iron out what I think I already know but am just holding back.
When talking pressure/flow with a Porty.
The Pump determines the flow correct? In conjuction with your tip sizes.
If I turn down the PSI am I turning down the flow also or is your flow ONLY determined by the pump and the tips?
For example..If I am cleaning with a 2 GPM pump and 9502 tips at 500 psi..And I turn it down to 250 PSI am I still putting out the same amount of water, just at different pressure??
Please help me clarify all this please!!
Also does it hurt to put smaller tips on a wand that machine has a bigger pump?? (Are you hurting the pump to not let it flow all the water is designed to put out?? Or is it just fine?
Thanks
Jordan
Thanks
Jordan
