- Joined
- Oct 6, 2006
- Messages
- 117,343
Starting April 1, there’s a new lower MSRPon two great products! Plus, we're throwing in a special limited-time offer forFREE Ultrapac Extreme.
- HOSS 700 Rotary Tool – was $3147,now $2595 – over 17% savings!
Get much better results with far less labor and higher productivity! The HOSS 700 is engineered to deliver 700 deep-cleaning passes per minute, delivering solution at precise rates and agitating thoroughly to dramatically improve cleaning results. Plus, the down force created by the HOSS 700 combined with optimized vacuum flow results in maximum extraction, reducing carpet dry times by up to 30% compared to standard cleaning wands. And it it's a great back saver! - CDV Inline Filter Box – was $552, now $399 – over 27% savings!
High capacity, low clogging inline filtration system captures carpet fibers and other debris before it reaches your truckmount tank to maximize filtration and vacuum flow. And it’s a snap to clean! - Special offer! One FREE Case* ofUltrapac® Extreme (4 jars) when you buy a HOSS 700, April 1-30, 2019 only.
