pro chem odor rescue
glenboy
MACOMB MI
GLEN
Ok. so i bought some PC odor rescue and i mixed 5 ozs to 1.5 gals of hot tm water and within seconds BOOM the shit was boiling white foam all over the freakin place in my van and so on wow this shit is deadly in a pump sprayer......can anyone share some mixing techniques wit me and application tech
carpetcleaner
Gilbert, AZ
Rob Litwin
I'm not sure what that product is but it sounds a lot like OSR. You should mix it in a bucket or watering can. The hotter the water, the more it foams. It should be mixed near where you are going to use it. You than pour it on and extract with a Water Claw.
Hastings, NE
Eric Valentine
Odor Rescue is Sodium Percarbonate, Sodium Tri Poly Phosphate (STPP), Surfactant Blend, and fragrance. The STPP is the main ingredient in a lot of emulsifier rinses.
CTI'S OSR says it has a proprietary blend of Oxidizers (Sodium Percarbonate), Surfactants, and deodorizers. I was told by a distributor that it also contains enzymes.
I would go with OSR, as I have heard from a few cleaners that Odor Rescue doesn't work that well, and OSR kicked butt.
