Prochem 405 heat exchanger coil assembly
I doubt you'll find anything used. Guys tend to fix and keep these beast running but you never know.
John Olson
Orem UT
John Olson
No used ones. If anyone might have one it would be Allen Equipment but it isn't a part that would normally be on a self. If it is in working order then the machine would most likely be worth rebuilding. We have exhaust HX in stock we can send you the catalytic id have to order as well as the Heli-Coil as you really have to try hard to break those so we don't keep them on the shelf.
