Prochem Everest 650hp Timing Belt tips
Village Idiot
It really is easy.......I've done several Hyundai engines (cars)
but you fook it up in your yard and your freshly bent valves are your problem..........if Jondon or your local distributor fooks it up................
Chandler Arizona
Justin Johnston
I always recommend replacing the water pump, tensioner, and idler pulley while you are in there. The water pump is behind the timing belt, and there is nothing worse than having the water pump start dripping 100-200 hours after doing the timing belt. The tensioner and idler pulley are just precautionary. It is an interference motor after all.
Reactions: Vincent Feehan
