Just by running extreme clean as my emulsifier has speeded me up.
Prespray only the traffic areas and no scrub then emulsifier rinse.
Nice work Doug, What kind of Machine are you using? Like I said I did noticed a big difference in the cleaning with that Everest over my Blazer. It cleaned much faster and Better with less wear and tear on your body. He was using a Ti wand with NO glide and it was running smooth. My pick was from a Double wide with oil all over the parking lot tracked into the cheap poly carpet. It looks like your was too. I went through A bucket of Cobbs and Slop and Gobble. It all works great. Maybe I don't have enough HEAT
I Don't have enough flow on my HOSS right now, I misplaced the little restrictors ( have the smallest one in ) I and need to order the valve kit.
I might have an opportunity to sell my machine and van to a friend who lives in another state. That is why I am asking about the machines. If he does not buy it I will probably sit tight for another year. I only have 1100 hrs on my machine. I am just starting my 3rd summer.
Mikey, My HF has been nothing but trouble. I was thinking about getting an Electric Boss Sprayer from Mytee. Are they any Good? 120 psi
Thanks
If you have less heat you may need more dwell time. Many people dobt take advantage of dwell time and work too hard. Add another oz or two to your mix.
I learned I could schmooze mrs piff while the presray was dwelling in her nasty living room and talk about protector, then invite her over to watch me clean so she could see the difference.
Sent from my LGL86C using Tapatalk 2
