proper way to remove dye from a candle wax spill..???
Scott S.
Scott
need insight.. and yes i removed all the wax. just couldnt get the color out from the candle..... (synthetic carpet)
so whats your method? and what chems are you using?
davegillfishing
dave gill
what color??
i did a yellow soy candle spill today.
pro solve gel and power gel
got the wax and color at the same time..
i have a problem with reds.
this one way yellow on cut pile and was fresh
H
harryhides
Scott, melting the candle wax out, works fine with white candles and some colored candles...... BUT
The softer the wax ( more likely to be boutique or home made ) or the darker the candle color, the more likely that using heat on the stain will result in your "setting" the color into the carpet.
Step 1/ Use knapping shears to cut off as much wax as possible.
Step 2/ Use a seratted edge or gum getter to brush off even more wax.
Step 3/ Use a gel, like pro-solve to dissolve before extracting the rest of the was.
Use no heat beyond hot water from your extractor, works every time.
