Protector tip size
Will a multisprayer handle that solvent protector?
I use a 2 gallon hydroforce for mine. What tip should I use?
we have left cobbs and or saigers saw the in our multi sprayer for essentially a decade the only issue is the siphon hose needs to be replaced once a year gets rock hard after a while ..solvent based protectors are all ideally suited to a 6501 tip
