ACE
My pressure at the wand seemed weak on the Steamway. I spent allot of time descaling and troubleshooting the machine. The issue turned out to be a bad pressure gage on the machine. I found this by using a test gage mounted to a quick connect. I decided to hook it up to a solution line splitter right off the wand. 500 PSI pressure, but only around 200-250 PSI when the wand is keyed. I have heard temperature at the wand discussed allot but never PSI at the wand. PSI ATW seems like a good way to measure what’s really hitting the carpet because there are allot of factors that can make PSI drop before it hits the wand: hose length, pump limitations, scale / restrictions in plumbing. For truck mounted cleaning, 150-250 ATW seems ideal depending on how the jets are set up. Be careful if you try this because the PSI gages are not rated for much heat.
