PTO/CDS perceptions
Chris A
Chris
I see more Hydramasters than anything else. My closest friendly competitor and I both came from HM and went to pro 1200s.
Personally the 47 cleanco has been around for years and I never here anything bad from owners, also they set the lift at 15
The only thing I don’t like about mine is the limited pressure on the heat exchangers. The gauge can say 1000 psi, but your lucky to get 800psi at tile wand!
Downsize the Jets on the wand.
The 6 rib 56" belt on my WM takes all of 5 minutes to change. Usually only once a year.
Has never failed on a job.
120 inches long!
Let them squeek too long and they will yank out your water pump or bust the fan
Does yours have a separate belt for the machine? WM does, and I'd hate to have it otherwise.
FB7777
Sounds like Jimmys unit is wearing out due to lack of use
Manufacturers recommend changing the belt every 6 months
Or in Ladwigs case.... every 5 machine hours
Reactions: Mike Pailliotet
