If any of you were buying a new machine, what would be more important to you? A machine that could heat to 220-230 but could only sustain that with an 04-06 jetting with a 50% cycle at best. Or would you prefer a machine that would hold 185-200 with 08-010 jetting @100%? Set pressure rating for this will be 450psi and temps are taken as the water leaves the machine at the solution line quick connect.
