Pump out for truckmount
Covert
Marcus
Does anyone know of a pump out system to add on a truckmount
That is. Affordable....easy to install..and works
I have used 2..3 in the last few years and they don't last....
Needed for large commercial jobs and tile jobs
Blue Monarch
Lincoln, NE
Dirk Wingrove
Curt Johnson used the "polution solution" and had good luck with it. I think that was the name of it. Don't know that there are any cheaper ones out there.
John Olson
Orem UT
John Olson
You can only pick 2 of the 3. The new Prochem pump outs are holding up extremely well much better then the old style.
How much are the new Prochem's do they work like the old one same pluggins and hook ups.
John Olson
Orem UT
John Olson
The pump out kit is $2000ish that is the pump out the float and bracket and hose. If you do not have a Prochem then you will need a float adaptor kit to mount the shut off float and the pump out nipple. I think it is around $80 bucks for both parts and gaskets. You cut out the whole then mount the bracket to the tank. I can post pictures Monday of all the parts. The labor savings not having to shit down to dump pays for it in less then a year.
:eekk:
if it doesn't have to be 12vt system, and you don't mind running a 50 or 100ft extension cord , any 1/2 HP sewage pump will work .
($250-$300 for a quality cast iron sewage pump)
If you run an in-line filter, any 1/2 hp sump pump will work (hundred less than a sewage pump)
the whole shebang can be done for under $400
