Pump problem..
White Collar
Bentonville, Arkansas
Nick Petersen
The water from my fresh water tank isnt being pumped. I have taken the little plastic top off in front of the truckmount and cleaned it out, I made sure the lever was turned to the on position, Ive made sure nothing was laying on the hose and that it wasnt kinked somewhere, still nothing. Other than that I'm not sure what else to try.
Its a blueline champ. any help would be greatly appreciated..
Thanks, Nick
packfancjh
Sparks NV
Chris Hagen
What type of fresh water tank and pump? Take the pump out and bench test it with a battery. If it kicks on it's a block in the hose somewhere. If it doesn't kick on it's either the pump switch or the pump. My guess is the pump switch went out.
Arizona
is there a inline filter anywhere...
can you tell if the pump is even coming on....
is there a flow switch somewhere..
