Pump question - Dual wanding with high flow
Jesse
Say I want to run two 3gpm wands off the same truck sometimes. If I use one 10gpm pump will it work well when I'm only using 1 wand or a hf @ 1.5gpm. Will using a big azz pump for low flow applications require a special regulator?
Thanks
Ron lippold
i have a 6.5 gpm pump and we dual wand with it one at 18 flow and one with 24 flow right at 6 agllons per minute. I cant dual with both at 24 flow......
yep.
My first TM has a Werner Hydrocell 10 GPM pump.
a bad azz pump, ask Bob..... and it can run dry
Like all pumps, water that doesn't get used simply by-passes
Thanks
That I'm not sure of..I don't thing so..
yep.
Thanks
yes..one of THESE...
